My stock lt1
List from an old post of mine:
Comp Cams "CC503" Grind# 276HR-12 part# 07-503-8 $250
Comp Cams beehive springs part# 26918-16 $174
Comp Cams retainters part# 787-16 $50
Comp Cams valve locks part# 648-16 $23
Comp Cams Pro Mag 7/16" 1.6 rr's part# 1305-16 $290
ARP 7/16" rocker arm studs part# 134-7103 $38
TrickFlow guideplates part# 30400623-8 $16
TrickFlow 7.2" chromemoly pushrods part# 21407200 $87
Felpro replacement valve seals part# SS72861 $19
I prefer a 10* lock so I figured I'd throw it out there for ya. I have no idea what install height comes out to be with 787 retainers.
http://www.elliotsportworks.com/
He does LS1 and LT1 cam/head packages for super cheap. Really quality work. Stage 3 I believe is $1700 and should bring you up to around 400+ whp. Definitely check out the website.
Definitely do shorter rear end gearing (if you dont care about mpg or you dont daily it)
Port your manifold and get it tuned for a larger tb. Some people say it wont give you any power but I believe otherwise
LS1 style air cleaner conversion also seems to be fairly straight forward and gives good gains.
