Need help with flexplate
Old Nov 6, 2019 | 03:52 PM
Adam1203's Avatar
Default Need help with flexplate
Need help with the flexplate I bought a tci 399173 flexplate if we install it the way the flex plate says to it binds up. If we reverse it with the weights facing away from the engine everything spins freely I checked to make sure the trq converter was seated several time properly and it is I'm 100 percent positive
Old Nov 6, 2019 | 05:22 PM
Adam1203's Avatar
I called tci they marked the flexplate backwards
