EVAP lines backwards
Old Nov 9, 2019 | 05:02 PM
Jon M's Avatar
Default EVAP lines backwards
So I discovered I had these backwards on the solenoid. I had no codes and have corrected them. What would have been the symptoms of them backwards? Been running rich on the right bank.
Old Nov 12, 2019 | 05:41 PM
Jon M's Avatar
Well I’ll take a whack at it. Normally I think backwards lines would not allow fuel vapor to escape the tank and when the solenoid opened, not much would occur. However, in my case, my solenoid is shot and is open permanently. I can blow air through it both ways. So essentially I have a vacuum leak no matter which way it is hooked up. And with it being stuck open, the vacuum is constantly pulling fuel vapor from the canister and at all times extra air is being pulled in. Once it is above 10 degrees, the new part will go on to see what happens.
Old Nov 13, 2019 | 09:47 AM
SS RRR's Avatar
Village Troll
EVAP stuff is just smog ****. Has nothing to do with fuel delivery. Is the right bank where you have the exhaust leak?
Old Nov 13, 2019 | 10:34 AM
Jon M's Avatar
Understood, but you don’t think a constant source of unmetered air won’t cause some issues? What is happening is essentially the same if I removed the tube and left it uncapped would it not? Kind of like a bad throttle body gasket
Old Nov 13, 2019 | 11:25 AM
SS RRR's Avatar
Village Troll
I wouldn't think only one bank would be affected if that were the case. I dunno. Get a replacement and see what happens.
Old Nov 13, 2019 | 11:46 AM
Jon M's Avatar
Got one. Waiting on weather
Old Nov 13, 2019 | 01:19 PM
Vicious95Z28's Avatar
It wouldn't effect just one bank. It's unmetered air but not a huge source of it. The IAC should be able to compensate. I got rid of mine altogether, tuned it out and put as plug in the intake where the nipple was.
Old Nov 13, 2019 | 05:17 PM
Jon M's Avatar
Well I didn’t think this was the golden bullet but I can say it idles better. Gas smell is less, idles smoother but still rich as Uncle Scrooge McDuck
Old Nov 13, 2019 | 05:29 PM
Spartan7's Avatar
The lines being "backwards" doesn't mean anything. All the solenoid does is open and close the valve, allowing engine vacuum to draw in fuel vapor. You can technically put the lines on either way and it will work. I doubt that a stuck open solenoid valve would cause any real issues.
Old Nov 13, 2019 | 06:12 PM
Jon M's Avatar
It was definitely part of my issue as it idles better than it did. Smoother, so I guess the proof is in the pudding? I was hoping to solve all issues but deep down I knew it wasn’t going to correct a right bank issue.
Old Nov 14, 2019 | 04:30 PM
Spartan7's Avatar
I'll bite. Completely suggestive, not to mention the placebo effect. It may have actually made a difference, but you have no data to back it up, not to mention it's only been one day, so it's way too soon to assume anything. But hey, you go right on being defensive. I'm sure you'll get more help that way.
Old Nov 14, 2019 | 05:06 PM
Jon M's Avatar
I’m sorry if you took me as being defensive, I was not. Several articles mention rough idle as a symptom of a failed solenoid. Also EEHack confirmed my idle leveled out vs before, so at the risk of sounding like a “Richard”, I do have data. That’s the problem with text, it provides no actual tone and the reader inserts their own impression of the author.
Old Nov 17, 2019 | 12:24 AM
Supercharged111's Avatar
My truck (98 K1500 350 Vortec) had the solenoid stuck partially open and when I replaced it startup and idle smoothed out a little.
