MSD Ignition for 97 LT1
Ok so just a brief history before I get into the meet and potatoes. A couple weeks ago I started having some bad misfires when operating under load. Typically the vehicle would be up to operating temperatures and under load (typically on the interstate) when I would experience the misfires. She only misfired a handful of times during city driving. I replaced the opti with the MSD distributor (PN 83811) after finishing the installation and testing her out, I was still experiencing misfires. I ordered the MSD 8.5 plug wires and the MSD GM dual connector coil under the assumption the coil was the correct fit. Turns out I ordered the wrong one. Yes, I understand OEM replacement coils for the later LT1’s are factory upgraded and I should have gone with one of those instead. Hindsight 20-20. BUT, I have been looking for an excuse to pick up the MSD 6AL (PN 6201) and I figured this may be just the reason to do it, if and only if the MSD universal wiring harness (PN 8876) will allow the coil to be compatible with the other ignition upgrades I’ve done. The dual connector coil doesn’t connect with the factory wiring harness, so if I get the universal harness and the 6AL, will it be compatible? The car is stock, but I plan on doing full bolt-ons within the next six months (including cam and valvetrain). Any help would be appreciated as I haven’t been able to find anything out and after contacting holley’s tech support over a week ago, I still haven’t heard anything. I understand the full ignition kit with the 6AL might be overkill considering my 97 Z28 is still stock, but like I said, I don’t plan on keeping her stock much longer. Thanks all!
