LT1 Walbro 255
Old Feb 20, 2020 | 05:03 PM
Cupples's Avatar
Default LT1 Walbro 255
fuel pump is a Walbro 255 with Hotwire kit
Fuel pressure when primed with key on: 30 psi
Fuel pressure when primed with jumper under the hood: 40 psi
shouldn’t these read the same?
pressure bleeds down 10 psi fast then slowly to 0 psi.
i have the fuel rail pulled up with the injectors intact to check for leaks.
i have checked the FPR (stock) vacuum line for fuel and there is none.
any help is appreciated
Old Feb 21, 2020 | 08:52 AM
chadtn's Avatar
Pretty sure the fuel pressure shouldn't bleed down like that. It seems like I remember reading there is an internal check valve on the fuel pump that can go bad. If you can safely eliminate the fuel pressure regulator and injectors as culprits, about the only other thing I can think of would be a tiny leak near the fuel filter, a bad check valve on the fuel pump, or maybe the clamps on the flexible hose in the gas tank going from the pump to the fuel lines.
My 97 Camaro suddenly became very hard to start. It would run normally once it finally fired up, but I had to crank it excessively to get there. When I hooked a fuel pressure gauge up I noticed the pressure would drop rapidly when the pump shut off, just like you described. I installed a new fuel pump and the problem went away. I briefly considered installing an inline check valve near the fuel filter as a cheap/easy fix. heh..
Chad
Old Feb 21, 2020 | 09:08 AM
SS RRR's Avatar
Village Troll
More importantly, what is the pressure when the engine is running and the vacuum line off the FPR? Doesn't the jumper keep the pump running constantly? IIRC I think the 255 pumps bleed down as described. Is your FPR adjustable?
Old Feb 21, 2020 | 03:52 PM
Vicious95Z28's Avatar
Chad
Chad pretty much has it covered here. If you have the fuel rails out and no injectors are leaking after the pump cycles off you have a problem in the tank. I’ve seen in many occasions the fuel tube between the pump and the pump module start to leak from a crack or deterioration. In some cases it’s a rubber hose and modern fuels are kinda hard on rubber. I have a Walbro 255 that came with my Racetronix Kit. I can’t verify the check valve being there to prevent bleed off but here’s what I can tell you. When a pump bleeds off the car won’t start on the first cycle, the two second prime just isn’t enough to get fuel up the lines and to the injectors and it’s not enough to fire the injectors. You’d need to prime two to three times to get it to start.
30# of fuel pressure is too low so that right there is telling you something. You should get a slight increase in pressure if you pull vacuum from the regulator but 30 is to low. These cars should be a bit over 40 running iirc. I think mine is about 49 actually.
Old Feb 21, 2020 | 03:55 PM
I would also say that if you’re kidding a significant amount of fuel pressure before the injectors the car should be down on power, falling down on the big side.
Old Feb 22, 2020 | 01:34 PM
Cupples's Avatar
Injectors are not leaking. FPR is OEM
but not the original one. Maybe 2,000 miles
I have the rail pulled up with the injectors attached.
pump is a Walbro 255 from Racetronix
with the Hotwire kit. Hose is the teflon
one and I am aware of its problems as the
first hose was split from packaging.
Racetronix sent me a replacement.
I see that the Racetronix kits come with a
different looking pump now (purple ends).
is this an improved pump? Mine is about
5 years old but doesn’t have 2,000 miles
on it. Guessing I just need to buy a new
pump and see if the pressure changes.
Old Feb 22, 2020 | 04:23 PM
I honestly don't know, my Racetronix kit has been in the car over a decade man.
Old Feb 27, 2020 | 01:03 AM
Ruken's Avatar
As previously mentioned and what I agree with, is the possibility of the Fuel Pump/Sender check ball. The ball is there to retain fuel pressure for a quick prime at startup. I have only had this issue twice on my own personal vehicles in the last 20 years. But when I worked for a dealership I've maybe seen it 5 or 6 times. Its one thing that is severely overlooked when diagnosing a hard start with Rapid Bleed off and lack of Fuel Pressure with KOEO.
Old Feb 27, 2020 | 06:20 AM
myltwon's Avatar
yup had the same happen in one of my vehicles. Caused long cranking hard starts. If you double keyed the ignition into the on position 2-3 times, essentially "priming" the fuel rail, it would start almost immediately though.
Old Feb 27, 2020 | 09:20 AM
SS RRR's Avatar
Village Troll
Before I'd explore the FPR first. If it were me I'd get an aftermarket adjustable. I can't remember which on to avoid if it's Holly or some other brand. Plenty of threads you can search that suggest the correct one. Install it and try to adjust it to 43.5psi with no vacuum at idle. Then take it for a drive with a pressure gauge taped to the windshield. Go through a few gears at WOT and see if your needle stays right around 40 to the 43.5 peak adjustment. If it dips to 30 then there's inadequate pressure somewhere. I do remember I had a 255 (many years and probably two fuel pumps ago) that would bleed off quickly. Car started right up and it never ran lean. Have you contacted Racetronix to ask them? There may be someone there who knows. Not sure these days.
I dunno, to me it seems normal. Especially if you aren't experiencing hard starts(?).
Old Feb 27, 2020 | 11:45 AM
BALLSS's Avatar
FWIW I have a Walbro 255 (pump only) I put in at least 15 years ago. It has always bleed off within 10 min. Car starts instantly. You hear the fuel pump prime for a few seconds when you turn key on
with a FP gauge when you turn key on FP should "immediately snap" to the correct FP..if it doesn't (read slow low needle climb) than pump is likely getting tired, clogged filter
I have a adjustable FPR I bought at O'Rielys. Stay away from anything Aeromotove
Old Feb 27, 2020 | 01:02 PM
myltwon's Avatar
A bad check valve will bleed down fuel pressure in about 30 seconds
Old Mar 2, 2020 | 03:05 PM
SS RRR's Avatar
Village Troll
Was just reading a post by Shownomercy/Man-Crush on another thread suggesting a "genuine 255 Walbro" pump. I googled those words and got this link:
https://www.highflowfuel.com/i-23904...fuel-pump.html
Which states:
A common side effect of high volume (and OEM) intank fuel pumps are their inability to maintain static fuel pressure when the vehicle sits for any extended period of time. This leads to a "hard starting" condition where the starter must engage continuously for 3-4 seconds (or longer) before the motor will finally start. This side effect is commonplace with all high performance, high volume fuel pumps including Walbro, AEM, Aeromotive, and Quantum fuel pumps. Our check valve resolves this issue once and for all, and can be used either intank, or externally. It features a high-flow design which uses viton seals and stainless steel internals which are compatible with modern pump gasoline as well as E85. This check valve will not significantly alter the flow capabilities of your pump, but it will make sure that the car starts instantly, every single time. We recommend installing an inline check valve even with a brand new pump, so the tank doesn't need to be dropped again a few months later.
Old Mar 2, 2020 | 08:07 PM
PARMY's Avatar
good find SS RRR. glad I saw this before I did my pump
Old Mar 2, 2020 | 09:13 PM
Shownomercy's Avatar
Man-Crush Warning
My fuel pressure falls off after a few seconds on ignition on. The struggles of big external pumps.
Old Mar 3, 2020 | 09:18 AM
SS RRR's Avatar
Village Troll
Always gotta be whipping out that big external pump, man-crush!
