Optispark?
Tough to trouble shoot over the internet. Often a no start can just be ignition module attached to coil bracket
did you check fuel pressure?
Cars that sit for a year or so invite wire chewing critters.....
BBK tb, an SLP 3finger air filter, and TPIS headers, and a SPEC(?) clutch setup. I put in a new cam, solid roller (630 lift) springs, and ti retainers. So like I said she screams now. Can’t wait to take her to the drags. But got a new set of 36lb per hr injectors from Bobby at fuel injector conn., and gotta get the pcm reflashed/programmed. Any suggestions? Is there a programmer I could buy that I could tune with?( If I install wide bands)? And thank you all for your help!
this is my first LT4 (I’m a old corvette bbc guy!)
