LT1 swap, please help!
Swapping body harnesses is a major pain. Not sure if it would be easier to Frankenstein the v6 computer to run the dash gauges/interior and have the v8 computer run the engine, or just change the entire car over. Either way will require some major wiring harness surgery. I don't think the LT1 computer used PWM to drive the cluster and the 98 cars present some unique challenges that differ from 97 back cars and 99 up cars.
It will be a lot of work. Good luck!
Chad
Drive by wire started in 99 I believe. Mine is a 99 and had it, I just swapped the earlier pedals in and a standard throttle cable, all the bolt holes and firewall holes are the same throughout the years.
Wiring is going to be the big one. The later style ABS is completely different, and the wiring is different accordingly. 98+ also have the EBCM/EBTCM integrated into the ABS modulator. On 93-97 cars, it's a separate computer mounted up under the dash. That will create a lot of problems for you in wiring. I know 99-02 use serial data for all the ABS indicators on the dash and for communication with the OBD port, so if you were to keep the 98-02 ABS, you'd have problems with the dash, and potentially communication with a scanner. I'm unsure of 98. So yeah, big can of worms there.
The best solution is the one I chose, which is to swap the entire body/dash harness and use all the wiring from your 94 car. It's not easy or fun, but is definitely doable. If you think you can handle this... have at it! I can give some tips if needed.
Seems like the some of the later racks had a little more of an offset in the neck of the rack. I think those still work on all models.....but I might be wrong.
Unless this is a labor of love for a vehicle you plan on keeping forever, I would not attempt the project. Swapping the mechanical stuff is the easy part. Getting everything to work in the other car is the problem. You're honestly probably better off selling both cars and buying the v8 car that you actually want. If your goal is to have a street car with every system functional, odds are you will get frustrated and quit working on it before it's ever fully functional again.
If it's more of a race car setup, an extremely expensive, but simplified option might be an aftermarket EFI system. Someone just posted the other day about an LT1 wiring harness for a Holley Terminator setup that uses a Dakota Digital module to drive the instrument console. It would be crazy expensive, but it would fast track the project and put everything in easy mode. If you've got that kind of money though, it would probably be better to just ls1 swap the v6 car. lol
Chad
OP, I thought this would be an interesting swap.. it sure was. It was definitely challenging and rewarding when done, but not fun at all. And I'm not shy around wiring.
The biggest issue is abs pump and Trans Am front light connectors.
