94 Z28 looking for some input
Old May 9, 2020 | 07:24 PM
Richard Reavis's Avatar
Default 94 Z28 looking for some input
Hi all long time reader first time poster, 94 Z28 LT1 been a long term project gone thru the woes of transmission and opti spark putting it back together now, with new pan gasket and MSD opti instead of a cheap one and thanks to everyone that posted on here save me a ton on what to look for and stay away from.
I have some questions and looking for input, this thing is a beast, someone loved this Camaro a lot back in its prime, have been in a few the same year and none of them roar like this dam thing does I am convinced this is a 383 stroker, it has 165k on the speedo doesn't burn a drop of oil, has BBK headers, throttle body and cold air intake,aluminum heads now comes where I need the input.
1) I had the 4l60E upgrade ( got 6 months drive time before opti spark went ) done to the trans 2 years ago yes its been waiting that long for me to finish the opti spark and timing chain, pan gasket debacle so it has the 5 pinion planetary and upgrades, my concern is I go down the freeway at 80 mph and I am running about 1700 rpm dam things gets mileage a prius dreams about, I have seen 35-38 mpg, am I hurting the transmission ? I believe it has the stock rear end and drawing a blank on on the ratio at the moment but at that low an rpm am I pumping enough fluid thru the trans? and should I swap out to a different ratio and if so which one?
2) At 1700 rpm going 80 down the freeway is that motor generating enough oil pressure? Not a lot of load at 1700 rpm but curious if this is normal ?
3) A/C delete curious if it was worth it ?, I know its actually more expensive to get it back up and running but with the motor in this car its not like its going to kill me on fuel economy.
Old May 10, 2020 | 08:59 AM
Germansheperd1's Avatar
Getting 35-38mpg and economy that a Prius can dream of I hope you realize today is Mother’s Day NOT April Fools Day.
Old May 10, 2020 | 10:06 AM
I knew I was going to get some doubters on this which is why I posted the question, I know it sounds like I am full of it but at 55-60 mph I have to kick the dam thing out of overdrive or it starts lugging bad around 1200 rpm and I am scratching my head on this too
Old May 10, 2020 | 11:13 AM
SS RRR's Avatar
Village Troll
Yeah that’s pretty common. My 395.3L LT6 with corvette pistons and fuel rail covers just clocked 42.87 mpg’s last week. I have it geared to a 1:1 where I can do 88mph at 850rpm’s. Welcome to the club!
As far as oil pressure is concerned I have an oil pressure booster that runs directly off the brakes! Bloody expensive, but worth it!
PS- It’s for sail, too. It’s a one-of-a-kind Super Special Camero. Has 130,000 on the clock.
$27,500 frim
no tire kickers
much have cash in hand for test drive!
Old May 10, 2020 | 08:17 PM
Bengtson95's Avatar
$27,500 frim
no tire kickers
ha! Not better than my 395.4L!!! With my electric turbo charger I can go 80mph and turn my engine off. Endless mpgs
Old May 10, 2020 | 08:30 PM
Yeah and I believe in the Easter Bunny too!
