Tourq converter issue
Old Jun 7, 2020 | 12:45 PM
ss27gogeta's Avatar
Default Tourq converter issue
So I got my car yeasterday it's a 95 auto transam and been working out some things. One of them being when its running it makes a grinding clunking noise especially when you go to start it. Sounded like it was around the flexplate tourq converter area so I remove the shield and looked around and noticed the tourq converter moves from side to side quite a bit. so I think that's were the noise is coming from but I have read that the tourq converter needs to be properly spaced with the flexplate. but I feel like it should not move side to side so much the bolts are tight. I was thinking about putting some washers behind the bolts to take up some of the space would that work. Thanks for any help
Old Jun 7, 2020 | 01:00 PM
98CayenneT/A's Avatar
You're saying your all 3 of your converter bolts are tight?
Old Jun 7, 2020 | 01:40 PM
ss27gogeta's Avatar
Yes they were my brother put a new flexplate on becouse the old one had a lot of missing teeth. Maybe the new one is thinner? The bolts felt as if they bottomed out before they could go all the way in. I went ahead and did put a washer behind eatch bolt and the noise went away. so a loose tourq converter is my issue. I won't drive it untill I'm sure the washers is an ok fix I'd rather not burn up my transmittion yet.
