PCV vacuum elbow replacement
Old Jun 24, 2020 | 05:07 PM
Spartan7's Avatar
Default PCV vacuum elbow replacement
I need to replace the commonly-ripped vacuum elbow on the driver side of the intake between the metal tube and PCV valve, as mine is coming completely apart. I have it taped now as a temporary fix, but eventually I'll need to replace this properly.
The original part, GM 12556257, is discontinued (of course) and no longer available, which was the whole hose assembly. I'd rather not use some straight vacuum hose, as it's a pretty tight bend and could kink. Both ends (on the PCV valve itself and the hard line) are 3/8". I thought about using a pre-molded 90 degree bend from another hose, or even something universal like this:
Amazon Amazon
Has anyone come up with another viable solution?
