Do I need a tune for the cc306??
Old Jul 11, 2020 | 05:54 PM
Bventresco's Avatar
Default Do I need a tune for the cc306??
I got a 97 Firebird lt1 I got the comp cam 306 in it untuned at the moment yes I will eventually get it tuned
at the moment it runs and idols fine only problem is sometimes the check engine light comes on randomly like a multiple misfire code popped up but it wasn’t misfiring (I even had a shop look into it)
so with it running fine without being tuned what can Problems could happen (I’m gonna eventually get it tuned) and I don’t drive it very often I’d just like to get it out every once and awhile if it’s ok without the tune for alittle bit
the specs of the cam is duration advertised-290/307
lift- .510,.540
Old Jul 11, 2020 | 06:16 PM
ElkySS's Avatar
Any cam change requires a tune
Old Jul 11, 2020 | 06:21 PM
Bventresco's Avatar
Yes ik I’m planning on tuning it but I’m wondering if it’ll b ok for awhile with it not being tuned Bc it runs and idles just fine without the tune
Old Jul 11, 2020 | 07:17 PM
SS RRR's Avatar
Village Troll
Just as long as your PCM runs in closed loop and you stay out of wide open throttle you’ll be fine.
most likely won’t idle for ****.
Old Jul 11, 2020 | 07:36 PM
Bventresco's Avatar
Wym if my pcm don’t run in closed loop
I usually stay out of wot anyways lol
the car idles just fine tho lol
Old Jul 12, 2020 | 12:17 PM
SS RRR's Avatar
Village Troll
Quite possible then you’ll run pig rich. Wouldn’t be a good idea to run that for long in open loop.
Old Jul 13, 2020 | 01:00 PM
ss.slp.ls1's Avatar
^^^Sounds and idles as expected.
