'My engine's toast' update - July
Old Jul 17, 2004 | 08:55 PM
'93 LT1's Avatar
Default 'My engine's toast' update - July
Thought I'd update you guys on what's been happening with the Formula.
I managed to remove just about the entire engine except for the block 'cause I don't have an engine hoist and I'm pretty sure the block would probably be just a little too heavy to take out by hand
Old Jul 17, 2004 | 09:07 PM
DietCoke's Avatar
Put the radiator cover (flat top black piece) back on. It's there for a reason, to let air flow through your radiator instead of up over it.
Old Jul 17, 2004 | 09:19 PM
'93 LT1's Avatar
I'll definetely be putting a cover over the radiator but it wont be the factory piece. Since I now have so much room behind the radiator due to removing all the AC crap, the radiator is going to be pushed back (towards the front end) a good 4-5 inches. It's goint to be set up completely straight rather than at an angle like it was before. I'll make some brackets that will secure it along the bottom and make a cover for the top out of a sheet of aluminum or something.
Old Jul 18, 2004 | 03:54 PM
Snow Dog's Avatar
good idea road racers try and do that as much as possible to maximize airflow through the radiator. just a thought since you care about looks it seems. during all the down time, get a dremel and polishing wheel and polish the brackets and water pump. heres what thatll look like.
http://frrax.com/rrforum/index.php?act=ST&f=1&t=1796&
