for those running guidep lates on Lt1's/
Regarding guide plates, use the ISKY adjustable if you want the RR to line up EXACTLY as they should vs using one piece guide plates on Gen 2 LT1 heads
Always check PR length. For a non decked block and heads (read using stock untouched heads & block) you should not need a different length but it is always advised you check. Use a Sharpie on the valve tip, lash the RR and rotate the engine 2 turns by hand, remove RR and look at witness mark. You want a narrow, centered, mark. One closer to the exhaust side of motor needs a shorter PR. Mark closer to intake needs a longer PR
