The new guy (help)
http://aldlcable.com/
Only downloadable software I think they have available for OBDII is scanning. You may have to buy a copy of Tunercat or whatever the other popular software was called. PCM Tune or some mess like that.
The programming software for OBDII LT1 PCMs will be JetDST.
For OBDII scanning software I currently recommend ScanXL Pro with GM enhanced parameters.
https://www.palmerperformance.com/pr...lpro/index.php
It's been a few years since I bought the above software, so I would try contacting them before buying.
Option 2 might be to convert to 24x/LS pcm so you could then use either EFI Live or HP tuners. I think both of them can be bought with data loggers/scanners.
Option 3 might be to convert to OBDI. You could then use freescan to scan and Tunercat or TunerPro RT to program.
Thanks!
Chad
I'd switch to another computer and engine harness.
