Tune moved to late model computer
Old Feb 10, 2021 | 12:57 PM
Jazz-LT1's Avatar
Question Tune moved to late model computer
I have a 1994 LT1 which has a tune that I like already. I'd like to consider moving to a later model computer and getting rid of the Optispark using the later model PCM and sensors. Is it possible to copy the tables from the OBD1 pcm to a late Model PCM or do I need a new tune altogether. I'm happy with the performance of the current tune and simply want to match that with the updated system. As you can see I don't know much about tunes.
Thanks,
Old Feb 10, 2021 | 08:25 PM
ACE1252's Avatar
Sounds like you are talking about doing a 24x swap over. You'll need to get it a new tune. Can't just swap it from an LT to LS pcm.
Old Feb 15, 2021 | 11:24 AM
Jazz-LT1's Avatar
Thanks man. I was really wondering if it possible to copy the fuel tables. I decided to contact my original tuner to see if they can help me out.
Old Feb 16, 2021 | 07:18 PM
ACE1252's Avatar
I think some of the map and rpm boundaries in the VE tables are different between the two PCMs. You may can do some interpolation to get some values, but I think dyno tuning a new table for it would be best.
