Come-and-go misfire I guess. Weird!!!
Old Dec 10, 2021 | 12:23 PM
Gojira94's Avatar
I think you'd see the opposite with an exhaust leak-induced lean condition. You'd get intermittently or steadily more fuel, not less. If you have a FP gauge, see what you get at KOEO. Should be 42-44psi on a stock regulator. And it should hold close to that for a while. If it immediately drops to below 20, you could have one or more leaky injectors or a ruptured diaphragm in the FPR. Latter would drip fuel out of its vacuum line on the pass. side of the intake when pulled off. With extra fuel introduced and not commanded by the PCM, the O2s would see it and probably command less or significantly reduce pulse width on tip-in due to the extra fuel in the plenum and exhaust.
