Terminator X - Anyone?
Old May 30, 2021 | 07:06 PM
AgFormula02's Avatar
Default Terminator X - Anyone?
Just checking if anyone here is running a terminator X on a LT1?
Old May 31, 2021 | 08:40 AM
Shownomercy's Avatar
Man-Crush Warning
yup best upgrade I ever did
Old May 31, 2021 | 08:55 AM
Looks like all I need is the efi crank wheel and the cam sensor components. (Since I am a 97)
I have a couple extra sets of LS coil packs.
beyond that it should be plug and play? (Maybe some wire extensions)
any other gotchas? Assuming the SW will handle the firing order change or do I have to re wire coil packs?
thank you
Old May 31, 2021 | 09:20 AM
Man-Crush Warning
If you want to make your factory dash work, you will need to do some thinking. Otherwise, give holley a good power and key start, should be good to go.
On mine I had to switch some wires around for the cam and crank sensor I am running but thats easy stuff.
Old May 31, 2021 | 09:37 AM
Thank you!
Stock dash is gone so that makes life easier.
Great to hear from someone first hand. If I run into any issues will PM you.
Old May 31, 2021 | 04:44 PM
Rob94hawk's Avatar
Pricey but it's all done. You can even use the Torqhead system with this.
https://www.eficonnection.com/home/p...-dominator-ecu
Old Jun 1, 2021 | 06:35 PM
Casey96SS's Avatar
This is all pretty cool stuff! How does the Holley tuning software compare to HP Tuners? It seems like the Holley might be a better long term better due to complete Torq Head system using an aging factory LS PCM?
Old Jun 1, 2021 | 07:56 PM
Man-Crush Warning
Holley is straight forward, as is most aftermarket tuning stuff. Whereas HPT is lots of trickery to get the PCM to do what you want it to. IMO of course.
Furthermore, you can get a canned holley to fire off with their handheld gameboy. Easy, peasy.
Old Jun 2, 2021 | 11:00 AM
AnthonyS's Avatar
I'm curious how much power is gained going to coil on plug and either the LS or Holley ECU. No doubt its a huge step up in reliability, driveability (if the tune is good), and potential. A 24x conversion with a different ECU might be in my future too.
Old Jun 2, 2021 | 11:11 AM
SAPPER's Avatar
I just sold my LTx 383 to a friend of mine and he's doing the Termi x swap on it. It was 24x swapped but I sold the kit when I pulled motor 6 years ago. But he is gonna get the EFI Connection kit again to run it.
