LS7 water pump
Old Jun 6, 2021 | 04:10 PM
JFH's Avatar
JFH
Default LS7 water pump
I installed a 2007 LS7 in a '69 Vette with Ridetech suspension. The forward heater hose fitting is too close to the a-arm and the hose is being pinched by the a-arm and is leaking. Does anyone know if the heater hose fittings can be relocated?
Old Jun 6, 2021 | 04:23 PM
QwkTrip's Avatar
You can pull out the stock hose stubs and tap the holes in the pump, and then install a 45° or 90° fitting.
Old Jun 6, 2021 | 04:31 PM
JFH's Avatar
JFH
Thought about that, but I'm not sure the 45 0r 90 would clear either.
