95 C4 Y-body corvette
This will be my first time recharging a system correctly(low and high side gauges). All the past times was with that "dummy gauge" that comes with the kit. Any insight on the procedure would also be helpful.
1) You’ll need a vacuum pump to draw it down to as close to absolute vacuum it’ll go. And then hold it there for a couple of hours at least. Techs that worked for me at a Honda shop 15-16 years ago would always leave them overnight for bulletproof assurance the system was leak free.
2) when adding refrigerant, to prevent introducing air into the system you’ll need to purge the refrigerant line briefly to push out the air that’s in the hose when you connect the refrigerant can. Then open it at the manifold and let the system draw in the refrigerant.
3) amount and type of oil and refrigerant weight are critical.
I'll check static pressure and go from there I suppose. I'd assume everything to be in working order. It's a 95 with a little under 12k miles. Thanks again
you can’t weigh it. Usually the assumption is there is none which may be inaccurate and result in an overfill. Oil can leak out too. All
depends on where your leak is. It’s likely a system this old will develop additional leaks at o-rings once refilled. Not trying to discourage you, but the DIY at home scenario is best with a completely dry system with a new drier/desiccant where you know what you’re adding in refrigerant and oil is an accurate amount of both. Equipment for evacuating all the old oil and any refrigerant that may remain is usually beyond the budget of most of us DIY guys. To minimize the cost at a shop for a simple evac/charge, we can go through the system, replace o-rings, schrader valve cores, orifice tube, etc and leak test with a vacuum pump. A shop will evacuate the system, pulling out the old oil and verify your home repair is leak free, and then charge the system with an accurate measure of oil and refrigerant.
