12v key on and crank source
Old Aug 3, 2021 | 07:54 AM
topdog911's Avatar
Default 12v key on and crank source
Installing a Holley Terminator X Where is the best place to splice into for a 12v key on and cranking source on a 95 camaro.
Old Aug 3, 2021 | 03:51 PM
Shownomercy's Avatar
Man-Crush Warning
Probably the OEM key switch?
Old Aug 13, 2021 | 06:16 AM
biketopia's Avatar
http://shbox.com/1/4th_gen_tech1.html
There's a lot of good reference info on that site, there's a spot in the fuse box that should be powered up during key on and crank.
Old Aug 16, 2021 | 12:43 AM
Catmaigne's Avatar
You could also use an add-a-fuse on the ignition fuse if you're just looking for a lower amperage source to trigger an external relay. It'll fit under the plastic fuse panel if you have a 93-96 Camaro.
