93 intake on a 94
thanks,
aaron
The 94 lines will be longer since they were made to attach at the rear corner and making them do a u-turn back the front corner would be problematic. You can get the lines from a 93 and use them. All years route inlet, return and evap/canister lines down the driveshaft tunnel from the tank alongside the rear brake line feed. The soft lines you see in the engine bay attach to the hard lines just forward of the tunnel brace, and make an outboard turn to just inboard of the pinch rail. There is a plastic guide/retainer that feeds them from there up the driver’s fender well behind the fender liner and inside the fender.
if you had all the parts and were bored enough to do it, it would work fine. IMO, not worth the trouble if you don’t have everything in hand to make the swap.
And yes, the 93 had 22# injectors whereas the 94-97 had 24#.
