Where’s the voltage regulator
Old Dec 26, 2021 | 02:45 PM
LTX's Avatar
LTX
Default Where’s the voltage regulator
I’m having an intermittent symptom start up issue. Sometime it’ll start right up, sometimes it’ll turn over once and make multiple clicks, and sometimes it’ll turn then click just once.
trying to figure out what the blame because all the connections look clean and tight. Last time the car was running, the voltage gauge reads in the middle and ignition voltage reads 12.08 on ehack. Then I god err code 16 electrical system fault.
So out of the battery, alternator, and starter where’s the voltage regulator on an LT1 F-body?
Old Dec 26, 2021 | 03:33 PM
Shownomercy's Avatar
Man-Crush Warning
Inside of alternator.
You could change POR to external if you want
Old Dec 26, 2021 | 04:18 PM
LTX's Avatar
LTX
POR? You lost me! What do you mean?
Old Dec 26, 2021 | 08:20 PM
Man-Crush Warning
point of regulation.
Its internal factory, but you can grab a new pigtail and run it where you want. On a factory setup, I would leave it alone.
