No crank but getting everything else
Old Apr 11, 2022 | 10:32 PM
LTX's Avatar
LTX
Default No crank but getting everything else
Starter not turning over. So thought it might of been the ignition switch again but I am hearing a clicking noise in that area. So I assume that’s the ignition switch working. And all wires seem to be connected.
im getting power to all lights and everything else.
where should I best be looking next?
I will add that prior to this issue a family member spilt water all over my keys. Took them apart and realized they are pretty much water proof and still worked but didn’t assume it would affect the resistor. Is this ever a problem? Tried a 2nd pair of keys I had and same thing.
Old Apr 11, 2022 | 11:20 PM
pdxmotorhead's Avatar
Whats your battery voltage ?
Check post to post then starter end of + cable to ground should be close. BOTH should be closer to 13V than 12..
Old Apr 14, 2022 | 04:01 PM
nomoneyz's Avatar
Did you put a light on the solenoid wire to see if it's getting power when your turn the key?
