4l80e swap questions
Old May 23, 2022 | 02:55 PM
nickp's Avatar
Default 4l80e swap questions
I picked up a 4l80e to put behind the Lt1 for a new ProCharger build. Can I just buy the generic 4l60e to 4l80e harness adapter to work with the 24x 411 pcm? Being the car is a 95 I am not sure if it would be different than the newer model LS 4l60e as far as it communicating with the pcm. Next question is, should the factory speedometer work with this set up? I see lots of LS cars 80e swapped, but not much info on our older models. The car is a 1995 Firebird with torqhead 24x system and the trans is a 2005 out of a 1 ton van, if that makes any difference Thanks for any tips or help guys.
