How to completely bypass neutral safety switch
Old May 29, 2022 | 11:47 AM
LTX's Avatar
LTX
Default How to completely bypass neutral safety switch
94 Z28 Automatic.
Old May 29, 2022 | 09:48 PM
shbox's Avatar
There are 3 things the park/neutral switch does. If you just need it for starter engagement, you can put a jumper between the yellow and brown wires. But that leaves the backup lights inoperable and the park/neutral signal to the PCM not functioning (important for the PCM to know) if it is not plugged into the switch. You don't post any reason for wanting to bypass it, but for a normally functioning car it's best to have a working switch.
