Compatible injectors ?
Old Jun 23, 2022 | 11:26 PM
Money_Pit's Avatar
Default Compatible injectors ?
Ive been trying to compare other injectors to the stock Lt1 fuel injectors and so far from what I have found, these looks like the best match. https://www.summitracing.com/parts/afp-8775008
I found that the body styles are the same and it looks to be like the plugs are the same as well. Should these fit into the Lt1 ? As I was searched they said universal but I really doubt they could just be thrown into any engine.
Old Jun 24, 2022 | 12:33 AM
SS RRR's Avatar
Village Troll
50lbs? No. I forgot what your mods are? You are N/A, right? Stock injectors can support up to ~420 flywheel hp. If you want a larger injector you can to to the Ford SuperCoupe websites to see if you can find some of their stock injectors for their roots 3.8L V6 engines. They are 30lbs/hr, at 43psi and same impendence (I can't remember if ours are low or high). Just know if you go with a fuel injector that flows more than the stock 24lbs you will have to get a tune.
Old Jun 24, 2022 | 01:00 AM
Money_Pit's Avatar
Im aware stock injectors are actually pretty good, actually found out from an older post of yours. My injectors are doing fine, replaced them 10k miles ago. Trying to find injectors for a semi built FI lt1 I plan to build when I’m done fixing / replacing old parts on my Firebird. I do appreciate that extra info about the tuning for injectors.
Old Jun 24, 2022 | 01:31 AM
Money_Pit's Avatar
I believe I found some actually now. What do you think of these ? I just never heard of this company “Fuel injector clinic”... I have found injectors before for the lt1 and they’re always either too small or upwards of 160 lbh
https://throtl.com/products/525cc-58...gaAorzEALw_wcB
Old Jun 24, 2022 | 11:37 AM
SS RRR's Avatar
Village Troll
I have never heard or used them so I have no opinion. I'm just a simple minded, N/A kind of guy. Perhaps the man-crush guy "Shownomercy" on here can give you some help?
Old Jun 24, 2022 | 11:44 AM
Money_Pit's Avatar
lmao man crush. I’d be happy to be the experiment here and let y’all know how I’m doing later on with them. They’re not overly huge, nor too small, they’re just right 😂
