Trickflow TFS-89036 fuel injector data
I have a torqhead 24x setup (LS1 PCM and coils on a gen II LT1). EDIT: This means I'm tuning with HP Tuners
I bought trickflow tfs-89036 with the expectation it would come with an injector chart, but I can't find data online and none was provided.
Can anyone tell me where to find the correct data? I contacted trickflow customer support two weeks ago and have not heard back.
I finally got a hold of Trickflow... and they sent me a chart with an Accel part number.
Strongly suspect I overpaid for a trickflow branded Accel part
https://documents.holley.com/accel_i...ons_150136.pdf
In case this link goes down, here's a copy/paste
ACCEL 150136 - 36# Hr Fuel Injector Specifications
Drive Circuit: "Saturated", R-C Voltage Suppression, 14.0 VDC
Coil Resistance: 14.5 ohms
Fuel Compatibility: Standard Gasolines and Ethanol Flex Fuels
Fuel Pressure: 300 kPa (43.5 psi)
Static Flow Rate: 252 gm/min n-Heptane
Dynamic Flow Rate: 7.56 mg/pulse at 2.5 ms, 10 ms period (100 Hz)
Approximated Time Offset: 0.70 ms
Approximated Slope: 4.20 mg/ms
Minimum Linear PW: 1.38 ms
Linear Flow Range (SAE): 15.3
Opening Time: 1.35 ms
Closing Time 0.67 ms
SMOV: 4.23 volts
SMOV: 4.23 volts
