1996 Trans Am
but wasn't too sure Trending Topics
Rich
the good stuff? We have bolt on lt1s in the 11's. It's not that hard to get a H+C lt1 in the 11's. Not to mention he should be able to easily trap 116-120MPH.Rich
http://thunderracing.com/projects/?action=read&pgid=82
There you go bolt on LT1 in the 11s, it should have hit 10s on H/c but the high mile stock short block let go. A 355 depending on how its set up should atleast be in the 12s on drag radials I would hope, it wont run for **** full weight on 18s. Nineballs, LS1 H/C, 400+rwhp car, hit like 13s in the 1/4 with no weight reduction and 2.5 sixty foots. If you want to set a car up right, it has to be on tires and light, only way it'll run good. Theres also plenty of 10 sec 355 cars out there, plenty of 11 sec h/c Lt1s. Your buddies set up should be in the 11s on tires hooking.
