LT4 fuel question
Old Jan 31, 2023 | 07:59 PM
Streetrod don's Avatar
Default LT4 fuel question
I am doing an LT4 swap into a square body Blazer. I am using an in tank pump and am ready to run the fuel line. I know that the fuel pressure sensor has to go In this line but I am not sure about a pressure regulator. Should I install an adjustable pressure regulator.. if so where in the line should it go? Would also appreciate a recommendation for brand of regulator.
Old Feb 3, 2023 | 04:42 PM
Gojira94's Avatar
The factory FPR that attaches at the (factory) rail will work fine. 43-44psi at KOEO & WOT, should see about 38-39 at idle. It's vacuum referenced at the passenger side of the intake. LT1 & LT4 use the exact same setup, except 92-93 Vette and 93 F-Bodies, rail to intake relationship is different. If the rail and regulator are gone and you're putting together something on your own, I'd go with the Aeromotive 13301 on the return side, and use the 20-60# spring. Remember, gauge or pressure sensor is on the inlet side, regulator on the outlet side of the fuel equation.
Old Feb 5, 2023 | 01:36 PM
Default Fueling an LT4
Thanks, but I think your recommendations are for the early model LTs. My LT4 is the direct injection version, with an aftermarket fuel pump I think it requires an 85# FPR. Since posting this I have discovered VaporWorx. Carl has graciously walked me through the system.
Old Feb 6, 2023 | 08:46 AM
shbox's Avatar
Kinda thought that. This is the Gen II forum, so you can see the confusion. Good luck with your project. Sounds cool.
