rocker stud question
Old Mar 9, 2023 | 06:02 AM
97ta388stroker's Avatar
Default rocker stud question
Does anyone know the arp part number for 7/16 rocker studs with the guide plate locator shank that will fit lt4 heads? I'm not sure what length I'll need.
Old Mar 9, 2023 | 01:23 PM
SS RRR's Avatar
Village Troll
They are standard SBC screw in studs. Nothing special.
Old Mar 9, 2023 | 05:46 PM
lt1-xjs's Avatar
I used the ARP 134-7103 studs with Trick flow 30400623-08 guide plates.
Old Mar 10, 2023 | 10:24 AM
sounds goods thank you.
Old Mar 10, 2023 | 12:55 PM
BALLSS's Avatar
IDK if the LT4 Hards align rocker stud to valve the same as LT1 but if so, consider the ISKY adjustable guide plates. For me they allowed "dead nuts" straight RR tip on valve contact. Some grinding of the guide plate halves so they fit closer together may be required....as per instructions.
