Peak power shift points.
Old Apr 17, 2023 | 08:03 PM
NewOrleansLT1's Avatar
Default Peak power shift points.
If this was your peak horsepower, what RPM would y’all shift this engine at? 6700? 6800? 6900?
Old Apr 18, 2023 | 04:49 PM
F14D's Avatar
Peaks at 6700. 200rpm over was always the recomendation. Signatures see to be a thing of the past now so do you have torquehead, coil packs per cylinder, 411 pcm; basically how come to 7k can you get? Optis run out at 7k.
Old Apr 18, 2023 | 07:25 PM
SS RRR's Avatar
Village Troll
I'd take it to the track and play around with different shift points.
Old Apr 19, 2023 | 09:20 PM
Yes my signature is old lol. I’m running a 411 pcm and a different engine from the signature.
Old Apr 19, 2023 | 09:31 PM
if I had HP tuners, that would be a good idea.
Old Apr 20, 2023 | 11:22 AM
SS RRR's Avatar
Village Troll
Why not run it as is?
Old Apr 24, 2023 | 07:23 AM
I wil. I need tires and was waiting for mine shaft fall temps lol. It’s currently set at 6650 shift points. Figured by the time the transmission shift, RPM should be about 6700 or so…
