94 Firebird overheat while idle
Both fans are pulling plenty of air. Once it gets hot, it never cools, even if I drive it 10-30 MPH. Should I assume my radiator is plugged up?
Do the usual check ups. Make sure you dont have any coolant leaks, make sure you have coolant. More importantly make sure your cooling system is bled/burped properly. Its a little tricky with the reverse flow set up.
Forgot to mention its a new water pump. Im going to change the thermostat and back flush the radiator.
