Turbo LT1s?
Old Nov 13, 2023 | 02:33 PM
Shownomercy's Avatar
Man-Crush Warning
Default Turbo LT1s?
Is this enough turbo for a hotcam and stock injectors? Worried my opti spark will blow a ring 😕
Should I replace the factory injectors? Will a single plane intake hurt my torque??
Old Nov 13, 2023 | 05:19 PM
SS RRR's Avatar
Village Troll
racecar
Old Nov 13, 2023 | 08:48 PM
Man-Crush Warning
Should I swap to a TPI intake?
Old Nov 13, 2023 | 09:26 PM
SS RRR's Avatar
Village Troll
Of course. TBSS intake bolts right up.
Old Nov 14, 2023 | 01:34 PM
Kfxguy's Avatar
Thats not enough turbo.
Old Nov 14, 2023 | 02:50 PM
wretched73's Avatar
That turbo is both under sized and over sized
Old Nov 15, 2023 | 10:05 AM
SS RRR's Avatar
Village Troll
... and it already has an oil leak.
Old Nov 17, 2023 | 02:13 PM
Blackbirdws6's Avatar
I'd consider removing the blockage for the water pump. Might cause cooling problems. Keep the factory injectors; aftermarket is junk.
Old Nov 19, 2023 | 11:03 AM
SS RRR's Avatar
Village Troll
It’s good to see you are being helpful! Listen to this guy, man-crush. He too gave me very good info on my build thread!
Old Nov 19, 2023 | 05:08 PM
Man-Crush Warning
Yea I just ripped it all off and went back to NA. Turbo life isn't for me.
Old Nov 19, 2023 | 06:29 PM
TrendSetter's Avatar
Boost lyfe isn’t for everyone
Old Nov 20, 2023 | 12:50 PM
tallrandyb's Avatar
https://youtube.com/shorts/1ePazQsp5...iwvqERnCIQ402-
That's a hotcam idle? I guess it's been a while since I've heard cams in that duration range.
Old Nov 23, 2023 | 01:41 PM
LTX's Avatar
LTX
60 psi should be good on stock injectors, tune and pistons.
Old Nov 24, 2023 | 11:24 AM
SS RRR's Avatar
Village Troll
Don’t listen to man-crush. Chronic liar.
Old Nov 29, 2023 | 12:18 PM
It'd run better if it was painted pink. You've changed.
