What is going on with this crank seal?
Old Jun 20, 2024 | 02:41 PM
thebufenator's Avatar
Default What is going on with this crank seal?
1993 Z28, I was under the car working on an A/C compressor swap and I saw this on the crank hub. No quit sure what this is, the crank seal should have the rubber part touching the crank, correct?
What is the metal sleave there? Decent oil leak coming from the front obviously.
Old Jun 20, 2024 | 03:01 PM
shbox's Avatar
Looks like someone tried a speedi sleeve to help solve a previous leak. The sleeve is used on the crank hub to try to restore a smooth surface for the seal to ride on.
