Fittings for plastic fuel lines
Old Oct 7, 2024 | 12:13 AM
Chris in Idaho's Avatar
Default Fittings for plastic fuel lines
I want to cut the plastic lines that run to the LT1 fuel rail and run them to a corvette filter/regulator mounted on the fender well. What kind of fittings work with the plastic lines after I cut them to length? Would it be some sort of compression style with an OD ferrule or would it be a barb that the plastic line goes over?
Ideally I'd find a 90 degree fitting that goes from the plastic line to female quick connect. Anyone know of such a beast?
Old Oct 7, 2024 | 10:08 AM
SS RRR's Avatar
Village Troll
Those I've seen just replace the line with braided stainless and a/n fittings into the fuel rail.
