Fuel issue
Old Jun 28, 2025 | 01:00 PM
stingr's Avatar
Default Fuel issue
So I thought possibly the reason I was getting lean afrs under boost was an exhaust leak.....which is there i can hear it. I decided to hook a fuel pressure gauge up. Keys on I see roughly 40psi. Idling it drops to about 38psi or so. When I go into boost fuel pressure drops to like 20psi. This used to run afrs I. The 11.3 range under boost.....it's changed goes super lean. Even with methanol spraying. I have the factory pump with a inline booster. Walbro 255lph pump. Pressure is controlled by an fmu which with my boost level should shoot up to around 90psi. Do you guys think this is a pump issue or possibly a regulator issue? Not sure what the symptoms of a bad regulator are.
Old Jul 3, 2025 | 04:42 PM
F14D's Avatar
If you pull the vaccuum hose off the reg and you smell or see wet fuel, then it's bad.
Old Jul 3, 2025 | 06:55 PM
stingr's Avatar
It looks like it's a bad oem fuel pump. I'm upgrading to the racetronix 255lph in tank and hotwire kit
