No start when hot
Old Oct 4, 2025 | 07:10 PM
SAINTZ's Avatar
Exclamation No start when hot
(5.7 lt1 m6) I can start up my car just fine when its cold. If I shut off my car or stall after driving for any longer than 15 min it wont start again until it cools down. I replaced the spark plugs, drained the radiator and replaced the battery. please help
edit- also replaced the starter, same problem
Old Oct 4, 2025 | 08:00 PM
Tommy42088's Avatar
Be more descriptive, does it turn over like its trying to crank but possible not getting fuel?
or does it click like its a battery issue?
Are the lights and interior gauges still working?
It takes details to get a response on here.
Old Oct 4, 2025 | 08:43 PM
SAINTZ's Avatar
no clicking, all electronics work including the gauges, it cranks but I cant tell if its getting fuel, the fuel pump primes but no start (when hot)
Old Oct 5, 2025 | 09:13 AM
BALLSS's Avatar
Confirming fuel and spark is basic diagnosis. Hook a FP gauge up to confirm if it has enough "pressure". It should immediately go to about 43 PSI when priming then drop to about 38PSI after prime
One common no start when engine is at temp but starts when cold is bad IAC
Old Oct 5, 2025 | 11:42 AM
Tommy42088's Avatar
I would start with checking fuel pressure and make sure the pump isn't weak and not working once it gets hot.
Old Oct 5, 2025 | 12:52 PM
irocbsa's Avatar
Might be a long shot, but the injectors might be leaking badly so the engine gets flooded when it's hot and it sits for a while. A fuel pressure gauge, as other have mentioned, will help you. For a simple test, heat the engine up, shut it down, let it soak for 15 minutes or so, and then try to start it with "clear flood" mode engaged. Very easy to get into that mode. Put the pedal to the floor and crank it.
Old Oct 5, 2025 | 09:18 PM
01WS6/tamu's Avatar
What year is your car?
Did this develop all at once or has it gotten worse over time?
I hear off your description it will crank but no start? Look at the tach needle and see if you see it twitching while it's cranking when it's acting up. If it's not twitching you have a no spark situation.
But gotta start at the basics sufficient fuel pressure, spark, and a noid light to check for injector operation. Ideally a scanner to look at data is the most important number one. But most dont have it or know good from bad when scanning the data list.
Old Oct 10, 2025 | 07:32 PM
SAINTZ's Avatar
Its a 95 obd1 car, I picked up the car a few months back but it has been doing this for as long as ive had it ( previous owner said it was sitting in a driveway for a while).
