Not charging - how to inspect the alternator
Thanks.
Brand new cost down there should be $129 to at most 149 bucks.
If the copper slip rings are NOT worn down, a new pair of brushes and a New Recifier should cost ya around $25 at a local auto electric rebuild shop.
Pry out the seals, and push a small finger dab of grease in each of the ball bearings, if you haven't been through SALT WATER they'll probably go another decade.
There should be a rebuilder nearby that will sell you decent parts - My last road trip around America I saw a rebuilder in almost every small town down there.
Have you checked for good BATTERY power at the altenator B+ terminal?
Also, need ignition signal at the regulator (I) pin
