LT4 Heads vs LT1 Heads
Old Aug 24, 2004 | 07:50 PM
5432LT1's Avatar
Default LT4 Heads vs LT1 Heads
So im going to get a set to have a friend of mine in my car club, who happens to be a god with port n polishing heads, do whatever set i get...but i was wondering, is it really that big of a difference to go with the raised lt4s for port n polishing? or is it just a slight better gain?....also i would have to get the lt4 intake too correct?...well then how big of a performance gain would i notice with the ported lt4 heads and intake against the ported lt1 heads and stock intake? thanks guys!
- WIll
Ok apparently i just found out the lt4 intake has no gain over the stock lt1 intake...so that being learned..still..the difference between lt1 ported heads, and lt4 ported heads?
Old Aug 24, 2004 | 09:35 PM
S8ER95Z's Avatar
LT4 has a better maximum potential..and flows better than the LT1 from the start.
(Visual Example LOL )
LT1 base <--------------------> Max
.....LT4 Base <--------------------------> Max
Old Aug 24, 2004 | 10:02 PM
TD's z's Avatar
the lt4 in my opion is over kill for most applications anyway... i mean it's alot bigger but, don't flow alot more at least from my experiances. although they should do good in a strocker and/or power adder situation (N2o turbo supercharger)
they're also way more exspensive castings than say.. ones already on your car
and if your friend is a porting god he should be able to get in the 290-300 cfm range with a 2.02 valve and a 205cc intake runner lt1 casting of coarse
if he can't then we can
hope i helped! any more questions pm me or give me a call at tea ask for tony
Old Aug 24, 2004 | 10:27 PM
5432LT1's Avatar
i believe he flowed 319 or 309 cfm on the last set of lt1 heads he did.
Old Aug 24, 2004 | 10:32 PM
Z8'S's Avatar
UMMMMMM Dont think so.Never heard of anyone getting that out of an "LT-1
Old Aug 24, 2004 | 10:51 PM
Snow Dog's Avatar
like tony said the lt4s are better, but in most cases they are overkill. they arent cheap as you have to buy them brand new. used isnt an option. if someone has a set they wont go for cheap and if someone has the engine they will not part it im sure. use the LT1s unless youve got major plans down the road and dont want to do heads more than once. if your going simple heads cam maybe even 383 just get the LT1s ported. oh and you have to use the LT4 intake with the LT4 heads. no way around that.
Old Aug 24, 2004 | 10:53 PM
5432LT1's Avatar
yeah youre right i just asked a guy in the club...it was 309 or something but they had it measure wrong or whatever that means? ended up being late 280s...they told me that its pretty close to impossible to get them over 300
Old Aug 25, 2004 | 12:33 AM
Dave95Formula's Avatar
What can you get me out of some AFR 220s or 227s...if you start from a bare casting and how much are we talking about....
Dave
Old Aug 25, 2004 | 09:00 AM
METALBEAST's Avatar
LT4 castings have more potential than LT1 castings. Out of the box the LT1s flow roughly 215 CFM @ 0.5 inches lift. LT4 castings flow 250 CFM @ 0.5 inches lift. Out of the box, that is slightly better than stock '98-'00 LS1 heads.
LT1 head flow data: http://www.chevyhiperformance.com/te...98/index4.html
LT4 head flow data: http://www.chevyhiperformance.com/te...98/index5.html
LS1 head flow data: http://www.chevyhiperformance.com/te...98/index6.html
Remember also that LT4 castings come with 195 cc intake runners versus 170 cc for the LT1. Most LT1 heads that have been fully ported and polished flow 270-290 CFM max. LT4 castings can flow 300+ CFM when properly ported. If you can get a used set for a decent price, go with the LT4s.
Old Aug 25, 2004 | 10:26 AM
Z284thgen's Avatar
i was talking to brent a couple weeks ago abotu my heads he did and he was saying they got some LT1 castings up in the 290's now and 230+ exh.
Old Aug 25, 2004 | 10:45 AM
TWS's Avatar
TWS
Strange,... best I got out of my stock casting '94 LT1 heads was 265 CFM @.600 and 260 CFM @.550.
Either my heads suck, or I'm the only one not inflating my numbers. (or the only one who had them on an honest flow bench)
Attached Thumbnails LT4 Heads vs LT1 Heads-fresh-94-lt1-heads-intake-ports.jpg   LT4 Heads vs LT1 Heads-fresh-94-lt1-heads-big-valves.jpg
Old Aug 25, 2004 | 02:38 PM
5432LT1's Avatar
Originally Posted by METALBEAST
LT4 castings have more potential than LT1 castings. Out of the box the LT1s flow roughly 215 CFM @ 0.5 inches lift. LT4 castings flow 250 CFM @ 0.5 inches lift. Out of the box, that is slightly better than stock '98-'99 LS1 heads.
You wouldnt know the casting numbers for the LT4 heads would you?
Old Aug 25, 2004 | 02:59 PM
METALBEAST's Avatar
The head casting number for the LT4 heads is 10239902 if I am not mistaken.
Old Aug 25, 2004 | 06:02 PM
Jordan57's Avatar
I don't have a LT4 intake on my LT4 heads. It is visa versa...lt4 intake requires heads but the lt1 intake will work on lt4 heads. At least as far as I know. Unless there is some spacer in there or something...i didnt do the work when the heads were replaced. Oh yeah I got mine for 600 bucks complete off ebay. If you can get them for a decent price...go ahead. Otherwise get the stockers ported.
Old Aug 25, 2004 | 11:02 PM
BlackWidow's Avatar
Your not getting over 280's with lt1 heads on a 2.020 @ .550 lift. And you can match up LT4 intake and LT1 heads you just have to raise the roof alot. LT4 is the way to go just keep it simple and be cost effective.
Old Aug 26, 2004 | 02:21 PM
5432LT1's Avatar
Where could i go to check that out..cause someone else told me they were 10239906
Old Aug 27, 2004 | 01:26 PM
Sidewayz 4.6l's Avatar
there is a website devoted to chevy casting numbers at www.mortec.com very thorough! I use them all the time here at AFR.
Just for reference the LT4 heads flow around 250cfm@0.500" lift while our comp package (which is 195cc like the LT4) flow's 275cfm@0.500" lift.
Had to add that last part, Right??
Old Aug 27, 2004 | 01:32 PM
METALBEAST's Avatar
Scroll down toward the bottom. The LT4 head casting number is shown as 10239902
http://www.geocities.com/meanracing/...ngNumbers.html
Old Aug 28, 2004 | 09:31 PM
ShadowLvr's Avatar
I have a question... On the LT4 heads vs the LT1, do you sacrifice low end torque? In my application, torque's as or more important than horsepower. I can almost garuntee I'm carrying more car than anyone else on here.
Old Aug 29, 2004 | 07:06 PM
TwoFast4Lv's Avatar
we have yet to really make more HP with a set of ported LT4 head then a set of ported LT1 heads....but we are working on it
The killer seems to be the intake. We should be testing a new intake I built very soon
