lt4 hotcam cut-off
i have camaro lt1 1995 man trans & i installed lt4 hotcam with a lot of modification like moroso ram air, TB 52mm, ported mass air, ported manifold & heads,1.6 gold rocker, lt4 valve spring, crank pulley, slp headres, accel ignition system, msd wire site & borla exhaust system (no cats).
my first question is:
1- where should be the cut off for my cam & the best rpm to shift (my computer have custom program & cut off at 6300 rpm) so waht u suggest?
i saw corvette lt4 red line at 6200 so i think for the lt4 hotcam should be more isn't it !!!
2- what do u think about my modification & how many hourse power u think i have, i am not planning to add any parts for now but i well be happy if u tell me any ideas & suggests so i do it later.
3- which plate should i put for the borla is it the closed or open one spieally for the long distance like 700m or 800m & what is the diffrent between the plates(no problem for the sound if its the best for power & torque)
Thanks a lot
Gears should be next if you don't already have them, with the t56 4.10s can be quite tame even on the highway.
For drag racing you might try shifting at 6,400-6,500. My only concern is the cheap springs in the Hot cam kit. Now you are listing LT4 springs? this will take it down some. I would worry about float with either one after any time running. I change mine once A year or so depending on how I run them.
rrght now with a GM 847 cam and K-Motion valve springs i am shifting at 6,900RPM on a stock bottom end. I have been doing that for a few years now.
I am running an A4 with a 12 bolt and last dyno untuned it made 395 RWHP SAE corrected.....peak HP at 6,800
Besides the valve springs and hacked up MAF you should have a solid combination
The engine had 18 k on it when I got it and has had an additional 30k since. We tore it down 6k miles ago and the bearings were perfect.....So I tossed in a set of off the shelf 77s stock size and along with a GM#847 and turned it up!
Shifting just before it hitts the 7,000 MSD chip for over two years now.
here are some things to look at
Dyno sheet before and after heads
MSN Page's
Page of what new motor was going to be and present mod's
Random pic's from last winter
any body knows a site that will sell it in good price or if i can find a second hand in good condetion.
thanks a ot
