What Kind Of Cam Should I Get??
Thanks, I needed a laugh tonight
And no, you dont need roller rockers or taller valve covers to put in a cam.
as for as a cam for your mods and the n20. i'd get a cam with a decent split in duration and lift. the cc306 likes n20 a lot, but you may want ported heads with that cam. then again you could go with the cc304 or 305. it depends on what your really looking for.
. The hotcam was hot about 10 yrs ago...it simply doesnt compare to todays latest profile cams. For the tunability issues its not that great of a performer...but does sound nice. I'm still laughing about the taller valve covers comment.....
And yes you will NEED springs and retainers if you go up in cam size...i.e lift. Roller rockers are not necessary but are a good idea for adjusting valves and less wear and tear on valvetrain components. Pushrods and lifters are a great idea also....however valve covers are absolutley in no way shape or form needed...unless you were going to run a a stud girdle or something odd like that.....and even then i'm pretty positive it would fit. I would recommend comp cams tho...their high energy series is great...give em a shout.....and yes 97silverbullet...you are an idiot.
They are a sponsor here and have a huge variety of LT1 cams, including NO2 grinds.
Combo hauls *** (untuned) and Im seeing teens for gas mileage (hoping the tune will bring that up some..) However Im sure it wouldnt pass emissions.. My friend sprays a 150 shot with the CC 305 cam and has gone 11.40s using shorty headers. Anyways..my point is if the 305 will pass emissions it appears to be a good cam to spray with.
With the 1.6/1 roller rockers you can use the stock valve covers, but you will need to cut off the drip tabs to allow them to properly fit. I put 1.6/1 Comp Cam Pro Magnum Rockers on my Vette and had to do this to get the covers to sea on the gaskets.
I would also recommend at least some mild porting of your heads if you are upgrading the cam.
I'd recommend springs and roller rockers with whatever cam you choose. It really depends on how aggressive your looking to make your car. I personally don't like mild or anything inbetween so I'll keep my humble cam opinions to myself. But at least get something at least no smaller than a baby hotcam and definitely use RRs and better springs, retainers, locks, 1-piece cmoly pushrods, etc etc.
X .504-.510 LIFT WITH 5/1 ROCKERS.536X.544 WITH
6/1 ROCKERS. I USE THE 5/1 ON THE STREET AND THE 6/1 ON THE TRACK. I LOVE IT!!! YES YOU NEED SPRINGS.
I passed smog easy with the hotcam and other mods.
