Air inlet hose part number??
I'm looking for the pn of the air inlet hose from a lt1, 1le road race option, if it really exists...
from "best of tech" CHP magazine states the 1le is the same inlet hose as the std lt1 camaro except the mute plenum is plugged oem.
Basically, I need an inlet hose with an elbow to connect my tb to my maf (smog exempt swap)
the part numbers given are 25147283:1le and 25147284 std lt1 and both of which are not valid part numbers. Any ideas?
Thanks.
Thanks.
Check out www.camaroz28.com Those guys specialize in LT1 cars.
Since you have part numbers, you could also try calling SDPC >>-->
GM#25147187 (for upgraded opti) $47.96 plus shipping from GM parts direct
When ordering specify NO A/C. do NOT get the export. it is like stock only with a 90 on the end
