4.10 or 4.56
Bolt on only car, going for low 12's with a M6
Which gear will help 60ft?
I am trying not to bog like i am now with 3.42's
Which gear will help total quarter mile time?
I need the Et's to drop considerably.
Keep in mind i will only have around 320rwhp and i need to pull 1.6 60fts.
Any helpful info please, i know alot of people run the 4.10's so they will probably be more popular.
thanks Roadtrip
But seriously, you may want to consider a 12 bolt or 9" rear end Thanks for the help
Thanks for the help
12 bolt shipping weight is 191lbs
10 bolt is around 150-160
I guess 8lbs is alot
On the ECM issues....
obd1 computers crash out if you hit 7k
obd2 computers will run past 7k, but how the tables are set up, you need to do some major tuning on the dyno to get them to run well up there.
Well 160 to 190 is a lot. Thats what i ment. I didn't know the weight of the rear ends.
Thanks for the info, might as well but the 9" .
Not really, when you consider how much harder you can beat on a 9". Clutch dumps at 6k on slicks should make up for the difference
