Car Problems.. same old shit.
Old Oct 27, 2004 | 02:41 PM
Vendetta's Avatar
Originally Posted by TwoFast4Lv
Well what some people call "More connected" others call a PITA I was just relaying what I See alot of to help and nothing more Five of the cars we had last year were Mustangs. F-Body's tend to be worse because the rear end is connected to this are with the TQ Arm
Good Luck Finding it man!
Thanks buddy. I'll keep you guys posted in here.
Right now it looks like I'm going to take it to another mechanic for a second opinion. If that doesn't work out, I'll start replacing parts- starting with motor mounts and the tranny mount.
Old Oct 27, 2004 | 07:33 PM
Snow Dog's Avatar
swap out the trans mount first. if that doesnt solve it. then maybe TC is not balanced anymore. try rotating it to another bolt hole on the flywheel. rotate just the TC not the engine. after that im thinking internal trans. input shaft or something.
Old Oct 28, 2004 | 06:34 PM
TJs98GT's Avatar
Captain Redbeard
the TC in his car is **** anyway, could definately use one a little higher, if he goes so far as to take it off and move it and then might not even be the problem and have to do it again to replace it he might as well just replace it with the one that should of been in there in the first place...
well, whatever you do, motor/tranny mounts, TC, lemme know and you know ill lend you a hand.
Old Oct 28, 2004 | 08:22 PM
Vendetta's Avatar
Thanks buddy, I'll let you know.
Old Oct 29, 2004 | 07:21 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Hope things get resolved. Good luck!
Old Oct 29, 2004 | 02:23 PM
Vendetta's Avatar
Thanks Carlos.
Old Nov 6, 2004 | 11:22 PM
NXSLT1's Avatar
I immediately noticed more vibration after I put in the poly trans mount, but it wasn't that bad at it's worst. Also, I just got dumped duals put on mine and now notice major vibration at certain rpm. Done any exhaust mods? It's worth a check.
Old Nov 21, 2004 | 08:28 PM
LFNDUST's Avatar
I had the same problem as your saying and it was a fucked up spark plug...so try that...its cheap.
Old Nov 21, 2004 | 09:37 PM
Vendetta's Avatar
Word is that it's an internal problem.
Old Nov 22, 2004 | 01:26 PM
Vendetta's Avatar
motor needs to be rebalanced.
Old Nov 22, 2004 | 01:31 PM
!LS1 11 Second Club
Sorry to hear.
If it makes you feel any better, the posi in my Moser 9" took a dump, along with several other rear end components. I haven't driven my car for a month, so I can relate a bit.
Can you afford to use this opportunity to upgrade for bigger/better/faster things since the motor's being cracked open?
Old Nov 22, 2004 | 02:07 PM
  #32
Vendetta's Avatar
Sorry to hear.
Nope, can't afford it since I've got another loan to pay off with the scooby. probably gonna end up selling her for a real low price, so if anybody is interested in an LT1 project, lemme know.
Old Nov 22, 2004 | 02:40 PM
  #33
ou812/z28's Avatar
my 94 did the same thing when i put my poly mount on. what i did to help it alot and almost eliminated it was cut a tire sidewall and puinch some holes in it for the cross member bolts to go thru., made one for top agianst the body and under the crossmember. then cut a piece to fit under the trans mount inbetween the member and the mt. try this and see what happens. bc mine was bad before but almost gone after.
Old Nov 23, 2004 | 10:40 AM
  #34
Aries's Avatar
Originally Posted by METALBEAST
Enisguy, it sounds like it could be your torque converter.
yep. I've had several go bad. Especially increased stalls in a stock housing.
They react just the way Enisguy is describing.
Old Nov 23, 2004 | 10:41 AM
  #35
Aries's Avatar
if you're serious about selling her shoot me a PM.
Old Nov 23, 2004 | 07:38 PM
  #36
Vendetta's Avatar
PMed ya.
