150 shot or not
Old Nov 11, 2004 | 07:24 AM
Slow TA's Avatar
Default 150 shot or not
My Lt1 only has 73000 miles on it and ive been spraying 100 shot on it all day long. I wanna do a 150, but I have a stock fuel system and stock bottom end. Do you think My car could handle it with no problems?
Old Nov 11, 2004 | 08:46 AM
96capricemgr's Avatar
I would upgrade the fuel pump. The bottomend is more than up to a 150 shot. I know of one b-body running over 400hp NA plus a 200+ an 80 shot, that is right two stages for a total of 280hp nitrous on top of over 400hp NA. People do not give stock parts enough credit.
Old Nov 11, 2004 | 09:48 AM
Lethalchem's Avatar
I'm new to Camaro's, but I've been hearing 150 is pushing it? My Z has an upgraded fuel system, and it's set up for nitrous (colder plugs, cam specs etc already), and the guy still told me it would be a gamble at 150, and recommended 100 for regular use. WHat's the general consensus?
Old Nov 11, 2004 | 10:50 AM
musclehead's Avatar
It's been said that a 150 shot is the most you wanna go with stock fuel pump and injectors. I say you can run a 150 shot stock. That's what I'm going to be doing when I start off in the coming summer.
Old Nov 11, 2004 | 11:07 AM
Scott96LT1's Avatar
150 should be alright. The bottom end will take it all day long. Still, a bigger fuel pump couldn't hurt but it isnt totally necessary.
Old Nov 11, 2004 | 11:16 AM
RacinLT1's Avatar
IMO a good fuel pump is cheap insurance. I ran a 175 shot on a stock longblock,and had an upgraded fuel pump. gotta remember,some of these stock parts are 10+ years old,why gamble the engine on a $100-140 part?
Old Nov 11, 2004 | 11:40 AM
dhdenney's Avatar
Had a buddy run 150 on completely stock motor, stock fuel system every time out.
Old Nov 11, 2004 | 01:38 PM
Lethalchem's Avatar
So the limiting factor is the fuel system? I've got a Walbro 255lph Fuel pump Kit, so does that mean I shouldn't be concerned about a 150 shot from a wet kit?
Old Nov 11, 2004 | 05:44 PM
musclehead's Avatar
You'll be fine.
Old Nov 14, 2004 | 10:39 AM
400hp ss's Avatar
I run a 150 to 175 on my stock bottom end and on a buddys car we shot a 200 shot and started running lean put a fuel pump and he hit a 300 shot stock bottom end with 91k on it dont know how long it will last but we will build a new one when it go's
Old Nov 14, 2004 | 10:47 AM
TwoFast4Lv's Avatar
The biggest question is WHAT kit are you running
Old Nov 14, 2004 | 05:26 PM
97blkz's Avatar
150 is a safe bet , to many cars running it with little to no problems. Buy the safety stuff and less worries!
Old Nov 14, 2004 | 08:22 PM
Walbro pump should be all you need as fuel system upgrades go.
