is my tps voltage right?
Old Nov 15, 2004 | 07:43 PM
1BadAsZ's Avatar
Default is my tps voltage right?
on the scanmaster at idle its .82 and at wot its 4.49. is this right? and if not could it have an effect on wide open throttle shifting?
Old Nov 17, 2004 | 03:51 PM
Mean Green z28's Avatar
I don't think it should matter. When you start the car, whatever value (eg - 0.82v) is taken as 0% and then should linearly increase to the max of between 4.30-4.60v. Make sure it increases linearly when you slowly press on the pedal.
for more info on this ... http://members.aol.com/InjuneerZZ/ScanMast.htm
