LT1 Vs. SBC whats the difference
thanks,
Matt
thanks,
Matt
They are very similiar but have subtle differences..
Block stregth would only be an issue if you were looking at a very radical poweradder/forced induction setup. The single biggest limit to the LT1 is the factory pcms rev limit of a little over 7000rpms it simply can not control spark beyond that but the motor itself is still fine. Really the LT1 and one piece rear main gen1 motors are pretty stout 450hp and 6500rpms being perfectly reliable as long as you keep it well lubed some guys far exeeding the 450hp and some taking it right up to the 7000rpm pcm limit. Many of the old rules do not apply these days would you believe that the iron head LT1s are 10:1 with cranking compression around 200psi and run on 87 octane, better yet guys are pulling the heads on old cop cars with over 150K and finding crosshatch in the bores so cylinder wear is almost non-existent.
