11lbs of STS Boost + New OPTI = COil Over system I guess?
Does anyone use the DynaSpark? Just wondering?
Thanks, lata, Ark
Nova5 - Yep what you said. However I spoke with my Tuner today and he said that he sees more failyers from the low voltage side (mostly old age) and recommended that I get the 2nd gen/version once its available. I understand that it replaces the opti completely.
Snow Dog - Yes I agree with you. Probably not got a ton to do with my boost level. I also Know that there are Good Opti's and Bad Opti's. I guess this NEW one I got was a BAD one! I just don't want to spend another $300 to have it go out next time I boost it up Or whenever it just decides to carp out again! AS for other Issues, I got most of that Covered. Built Turbo specific motor, Built Tranny, Upgraded every part of the suspension, and I got Meth for when I boost up way HIGH. I am in the final stages of setting up this project. I have bin working on it for over a year now.
I had good luck from My last (OLD) opti BUT when I built this motor I went with the vented (improved) version and it craped out in no time at all. That's just to hit and Miss for me. Time to try something NEW! Thanks, Lata, Ark
PS - I am still going withthe Delteq and as soon as they offer the 2nd gen stuff I am eliminating this piece of Junk totaly! Thanks, Lata, Ark
Lata, Ark
Delteq +1
The only part of the opti you will need is the optical portion which looks like a metal disc with open notches around the outside. You'll be fine with removing the remaining parts of the broken rotor and sealing her up.
