LT1 durablity?
Old Dec 29, 2004 | 06:44 PM
96blackz28's Avatar
I run the **** out of my Z28, its got 135k on it, still running strong, at about 125k my water pump went out and leaked on my Opti, that sucked, had to change Opti and waterpump. Also had to change intake gasket, and fuel pump soon after that.
Old Dec 29, 2004 | 07:26 PM
~JOSHUA's Avatar
Thumbs up
My beater is a '94. It has just passed 125k on the clock. I just spent the last two mornings underneath my car changing the water pump. Luckily the opti was spared. I hate driving my '02 in anything but clear weather so the wrenching @ 4am in 30degree weather in the few hours before work was mandatory. Other than that I've had no problems with my LT1. I bought it with 94 k and put full bolt-ons, raped it heavily-daily, before I got the 'hawk and decided that my '94 was no longer the "whip". I drive it easy now and I think it has at least another 40k before I'll even THINK about a rebuild.
Old Dec 29, 2004 | 07:52 PM
jocko's Avatar
are they more reliable than the ls1?
Old Dec 29, 2004 | 08:00 PM
SAPPER's Avatar
IMO, hell yes. I own both and haven't had a single issue with my 02 z, but it only has 23k on it. Oh, but the fr rotors keep warping and it ruined my caliper, warranty covered it though. I bought it used and the r/s cat was replaced at 4k. I guess i see it as the all aluminum motor just scares me and no room to bore if something happens. I run the **** outta my LS1 and go easy on the wifes Imp, but she runs it hard w/ a hotcammed 136k motor. But it will have the heads pulled next week for a check up since it's garaged for the winter. and probably new bearings so I can juice it a little.
Old Dec 29, 2004 | 08:21 PM
LT1Burnout's Avatar
well ive got 134k miles on her. i cant possibly count all the money ive dropped in her just keepin her running. the LT1 motor itself has had not a problem, its the rest of her. everything from taillights, windowmotors, blinker, headlights, fog lights, fuelrail, optispark, rebuilt rearend, rebuilt tranny, new driveshaft, broke and replaced front sway bar, now on the 3rd waterpump, new radiator, heater core, and custom fan switch.. just to name a small few. why i put up with her.. a mystery.
Old Dec 30, 2004 | 09:36 AM
~JOSHUA's Avatar
I own both engines. Honestly, I like the LS1 more. It is MUCH easier to work on, and I think that it's a killer when it comes to performance. I love the Gen 1 & 2, but Gen 3 is tops in reliability and performance. ( if you can live with the possibility of bent PRs on a miss shift, and minor piston slap) I think the Gen 3 is the new king. I have my blindfold on, the firing squad may fire when ready.
Old Dec 30, 2004 | 09:52 AM
outdooricon's Avatar
I'm confused, aren't the lt1's gen 3?
Old Dec 30, 2004 | 10:43 AM
BRENTT94Z's Avatar
No!
Gen4
Its the body style not the motor!
Old Dec 30, 2004 | 10:50 AM
BRENTT94Z's Avatar
I am pretty partial to the LT1.
I turned 163K on mine before I rebuilt it.
I have had 2 different cams in it since 121K and ran over 400lb's of nitrous through it. I Installed the CC306 when I turned 156k and ran strong until I rebuilt it. It was running 7.9's @90mph in the 1/8 on motor. Only reason I rebuilt it, because I picked up a 383 stroker rotating assembly for cheap!
When I tore the old assembly down the bearings and piston were still in great shape. The cylinder walls were perfect. The only oil it used was what dripped past the rear main.
Old Dec 30, 2004 | 11:07 AM
METALBEAST's Avatar
Originally Posted by BRENTT94Z
No!
Gen4
LT1s are Gen 2 small block chevy engines AKA SB2. Thus, my signature
Old Dec 30, 2004 | 11:26 AM
96capricemgr's Avatar
I recently aquired a 95 Roadmaster Wagon with 172K on the clock, motor looks to have never been touched, tranny feels like it has been worked on though. Drives like a dream and runs smooth as could be.
Old Dec 30, 2004 | 11:27 AM
  #32
lol, ok I understand now.
Old Dec 30, 2004 | 02:20 PM
  #33
BRENTT94Z's Avatar
Ok, Wait, now Im confused!!
Ive been under the assumption this entire time that the gens are the body make such as 1st gen= 1967-1969, 2nd Gen=1970-1981, 3rd Gen=1982-1992, 4th Gen= 1993-2002!
So now we have Gens for our motors??
Old Dec 30, 2004 | 02:33 PM
  #34
Yeah, otherwise we would say I have a 5.7L in my camaro what pushrods do I need and you could get at least 4 different answers that while all could be right only one would be right for your 5.7. The pre-LT1 stuff is all called gen1 even though they changed the crank seal and added roller cam provisions, the LT1, LT4 and L99 are the second generation and the LS1 line of motors including the tuck engines and LS6 is gen3. Really though the LT1 should be considered a generation of the original smallbolck but the LS1 is a whole new design. Sort of like calling the Ford modular motors gen4 flatheads, built by the same conpany years later but that is all they share.
Old Dec 30, 2004 | 06:23 PM
  #35
FIREHAWK #07's Avatar
My friends LT1 had 120K miles on it when it was taken apart due to him taking all the way to 6700RPM spun a bearing, but piston walls were like new.
Old Dec 30, 2004 | 07:52 PM
  #36
SAPPER's Avatar
OK, the gen 1 sbc are the old style type motors even when in 87 they went roller. the Gen2 are the LT1's, reverse flow cooling etc, the Gen 3 are like the LS1's today. Symetrical runners differrent block, yatta, yatta. Not body styles. The Gen ? in body styles refer to Camaros, thus being 67-69 Gen1, 70-81 Gen 2, 82-92 = 3, 93-02 = gen 4
Old Dec 30, 2004 | 08:22 PM
  #37
LT1Burnout's Avatar
LoL
well considering all my LT1 hassles, id be the last to pull the trigger..
Old Dec 30, 2004 | 09:27 PM
  #38
Very good grasshopper you have learned much today. I suppose it would simplify things if they called the f-body like they do the Vette(c5 for example) instead of gen use "f" and have f1-4 and hopefully soon an f-5.
Old Jan 1, 2005 | 09:47 PM
  #39
Vendetta's Avatar
Both motors are stout as hell, it's usually a matter of opinion beyond that. LT1s have some ignition problems, LS1s have some valvetrain problems.
