Times with the 224-230
Old Jan 4, 2005 | 05:26 PM
97LT1's Avatar
Originally Posted by Mikey 97Z M6
Couple things:
1. First and foremost, the little button located between the shift key and tab key on the left of the keyboard,,,,,, use it, your post gave me a headache.
2. I don't hate the 224/230 cam at all. I think it's a great daily driver and decent performance cam.
3. The highest number I've ever seen from that cam is 375rwhp. I've seen dozens of numbers from that cam and that is the highest. The average seems to be around 350-360ish.
4. There are just too many variables with a dyno/operator. For instance, I've seen up to 25rwhp difference between corrected and uncorrected dyno data. That is a HUGE difference IMO.
5. Another reason the 224/230 cam is getting a bad rap is because it has 6deg more duration than a hot cam (intake side), and yet produces almost exactly the same numbers. One would think that a cam with that much more duration would produce better performance.
97LT1-
Are you looking for 400rwhp or just 400 crank hp? I was assuming you wanted 400rwhp when I commented previously. If all you want is 400 crank hp, the 224/230 should get you real close. Figure 13-15% drivetrain loss for T56, closer to 18% for automatic.
Mike
Hey buddy what do you think i want? 400 rwhp
Just gotta get the heads ready.
I think i am going with the 306. Hey man any problems ahead of time i should know about with this cam. I have heard of some guys having a little break problem with it because of vacume. How about gas mileage for this cam? (not really concerned , but curious) Lastly somebody answer my question about fuel concern with the 306.
Old Jan 5, 2005 | 01:37 PM
BadCamaro's Avatar
what is the size of 306 cam?
Old Jan 5, 2005 | 01:53 PM
Mikey 97Z M6's Avatar
230/244
Mike
Old Jan 5, 2005 | 02:39 PM
Jordan57's Avatar
Had a cc306 in my buddies 97 z. It was an auto and real heavy cuz it was a vert too. Untuned it ran alright...no vacuum problems. Gas mileage was about the same too. Get it tuned and it will run real hard!!!
Old Jan 5, 2005 | 04:56 PM
BadCamaro's Avatar
230/244
Mike
what about the lift number?
Old Jan 5, 2005 | 05:07 PM
Jordan57's Avatar
.510" intake and .540" with 1.5 rockers I do believe
Old Jan 5, 2005 | 05:22 PM
97LT1's Avatar
Is it safe as far as piston clearance with the 306 with 1.6 rockers??????????????????????????????????????????? ?????????????????????????????????????????????????? ????????????????????????????????????????????????
Old Jan 5, 2005 | 06:07 PM
Jordan57's Avatar
Yes...my friend had a stock shortblock, 1.6rrs and the cc306 cam...all was fine!
Old Jan 9, 2005 | 06:36 PM
Saladbar's Avatar
I got a friend w/ the high lift version of the 224/230 in his 383. Combined w/ LE heads.. Made almost 420rwhp, and ran high 11's w/ ease.
Best 1/8 mile was a 6.75@100 - courtesy of yours truly . Now he's building a SR setup w/ AFR227's.
Old Jan 10, 2005 | 12:30 AM
FIREHAWK #07's Avatar
i am also thinking about getting a cc306 in my car....... what do you guys recommend upgrading when putting this cam in my car...... besides the obvious of springs, retainers etc.... what about tb, injectors, fuel pump, lifters.... etc... btw i have 85,000 on the oddometer........
